Vodafone has changed their pricing structure for their data plans after the launch of the
iPhone 4. All of their plans (2G/3G), regular or iPhone, cost the same now. They have discontinued their over priced iPhone plans. This would primarily be because they are no longer an official carrier for the iPhone in India. They have two parallel plans due to the different APN that is configured by default in the iPhone.
Yes.. If you've followed the steps in that thread and everything is working for you then it is fine.
Do you know when / what date this has happened?
You are right. Vodafone does have 2 data plans. One is the regular plan and the other is for the iPhone. In terms of price, data connectivity and speed both of them are the same. The only difference is the APN that is used. The regular plan uses the "www" APN setting whereas the iPhone plan uses "iphone" as the APN.
As of iOS 4.3.3,
Apple still had the Vodafone India Configuration file in the iOS firmware (meaning Vodafone was considered an official iPhone carrier). I haven't checked if it has changed in iOS 4.3.4. For this reason you cannot see the "Cellular Data Network" option under Settings when you use a Vodafone SIM. The ability to change the APN is restricted on all official carriers.
So, if you have the regular plan activated on your connection you will still be able to use the data service. But the iPhone will use the "iphone" APN by default (unless you have a Configuration Profile installed with ApN as "www"). Vodafone in turn will charge you like a pay as you go plan. This happened to me and I only found out when I got my bill. They later reversed the charges on my bill after I asked them how I could have two 3G plans active on my connection (Regular & iPhone plans).
Interesting. But we can add a custom APN entry using the iPhone tool or that co.nz site?
@hitman Vodafone is no longer an authorized carrier for the iPhone in India. Atleast not for the iPhone 4 (see Apple website). Official Indian carriers are Airtel & Aircel.
Almost all of the official carriers worldwide restrict APN editing. This is through the setup in the Carrier Bundle files in iOS. Apple has not removed the Vodafone India carrier bundle in iOS. That is the reason we can't see the option when using a Vodafone SIM.
Try any other SIM apart from Vodafone/Airtel/Aircel and you will see the option to edit APN. I also have a BSNL 3G connection. Whenever I use that SIM I can edit the APN.
Which BSNL 3G connection do you have? Which Plan? I am thinking of getting one for when I am out of cities in outdoors as a backup.
Well it's up to Apple to fix it and remove the Vodafone carrier bundle file from iOS. It's actually a pain for me as I'm on a corporate VMC data plan and need to install a configuration profile for the APN.
Your unfilled amount does not include discounts or adjustments. All that gets added when the monthly bill is generated. It doesn't impact your credit limit. I have a Rs 3000 credit limit and there have been months when my data usage was equivalent to Rs 6000 or more. They never stopped any of my services. Although I wish they had a way for postpaid customers to track/view data usage.
I remember a friend who was working with Wipro 2 years back and they had UNLIMITED Data from Vodafone as part of Corporate plan.
Are these kind of deals still available on Corporate plans?
I am on consultative status with a few Corporates so I could avail of these plans but I've got to know what options are available and which Corporate + Vodafone deal offers it.
Garfield if you have any such info and want to PM me that would be great.
