doctorgnanam
i have been usin BSNL broadband 250 plan from dec 2006 with Huawei WA1003A modem , since 2 week i am not able to connect to the broadband , i called of the BSNL officer who incharge of that , he came to my home and he tried is level best to repair it but he also not able to connect to the broadband , he thought it may be problem in modem so he changed it with UT300R2U ADSL2+ modem but then also my computer not connectin to the broadband , then he said it may me some problem in ur computer , so i deleted all my old software and re installed WINDOWS Xp in my computer , but then also no good result ..... pls help me ...
1. light in the modem POWER, DSL , LAN lights are ON only no problem in that .
2. my internet explorer opens 192.168.1.1
3. username : admin password : admin
4. in modem diagnostic its shows Test authentication with ISP : FAIL
Test the assinged IP address: FAIL
Ping default gateway : FAIL
rest of other options are PASS
5. while START > run ping 192.168.1.1 -t
it shows Reply from 192.168.1.1 : bytes=32 time=1ms TTL=64
what may me the problem ?....
whether its my computer problem (or) BSNL ISP problem (or) UT300R2u ADSL 2+Modem problem
pls provide ur suggestion ...... Thanx in advance ....
DEVICE INFO :
[link]http://www.orkut.com/AlbumZoom.aspx?uid=14039457958184267626&pid=1204230975765&aid=1[/link]
WAN SETUP :
[link]http://www.orkut.com/AlbumZoom.aspx?uid=14039457958184267626&pid=1204231120616&aid=1[/link]
PAGE 1:
[link]http://www.orkut.com/AlbumZoom.aspx?uid=14039457958184267626&pid=1204231286521&aid=1[/link]
PAGE 2:
[link]http://www.orkut.com/AlbumZoom.aspx?uid=14039457958184267626&pid=1204231167507&aid=1[/link]
PAGE 3 :
[link]http://www.orkut.com/AlbumZoom.aspx?uid=14039457958184267626&pid=1204231251234&aid=1[/link]
PAGE 4:
[link]http://www.orkut.com/AlbumZoom.aspx?uid=14039457958184267626&pid=1204231205957&aid=1[/link]
PAGE 5 :
[link]http://www.orkut.com/AlbumZoom.aspx?uid=14039457958184267626&pid=1204231329854&aid=1[/link]
LAN SETUP :
[link]http://www.orkut.com/AlbumZoom.aspx?uid=14039457958184267626&pid=1204231476278&aid=1[/link]
DIAGNOSTIC :
[link]http://www.orkut.com/AlbumZoom.aspx?uid=14039457958184267626&pid=1204231430163&aid=1[/link]
DEVICE INFO :
WAN SETUP :
PAGE 1:
PAGE 2:
PAGE 3 :
PAGE 4:
PAGE 5 :
LAN SETUP :
DIAGNOSTIC :
