WiFi Connection is not working in TD-W8951ND modem with BSNL connection
  • Thread starter Thread starter brathisv
  • Replies Replies 5
  • Views Views 11,545
brathisv
bsnl
Hi All,I am new to broadbandforum. I have used BSNL broadband connection, recently i bought TP-Link TD-W8951ND modem router. I am able to connect internet via LAN, but via WIFI i am not able to access internet though in my mobile and tablet wifi is get connected but internet not accessible.Please help to configure the modem.Thanks in advance,
Alright, thought so. In order to be able to use wifi, you need to set modem mode to ppoe (presuming you're on bridged now) , then enter username password into the modem itself. You, now should be able to access internet on wifi. And for the devices connected by lan, no setting is needed (you no longer need to dial, just plug in the lan cable and you're good to go). Just to be sure, when connected, right click on the connection icon in the task bar - go to properties - tcp/ip properties and set everything to auto.
