Hello brothers, i am using ZTE modem for Net plus at my office.
I followed the guides here to unlock the modem and was able to enable admin access for modem.
Netplus provides 1 roaming Net+Roaming SSID and normal SSIDs 2.4 and 5ghz each.
Earlier when using wps, I was able to connect printer to 2.4 ghz SSID and everything was working properly.
After unlocking, i have setup the things as they were with 2.4 ghz and 5 ghz SSID and 1 net plus roaming SSID.
When using wps to connect with printer, the printer is connecting to netplus roaming SSID due to which the printer is not showing in printers.
I want the printer to connect to 2.4 ghz SSID
Kindly help me solve this issue.
Thanks
Thanks
