How and what settings do i enter for my iPhone to work on a wireless Linksysrouter.....i get connected to the router but it says that it cant connect cos it cant find the server...pls help
* Go to Settings.
* Select Wi-Fi.
* Chose a network.
* Select the blue arrow next to the network you are connected to.
* Select DNS.
* Change the IP Address to 208.67.222.222
.........................................>>>>more
Correct DNS settings (using OpenDNS)
If using your router as the DNS server fails, or if you prefer to use a public DNS server, I highly recommend using a DNS server hosted by OpenDNS. OpenDNS is a safer, faster, and smarter way to navigate the internet. To use OpenDNS as the DNS server, change the IP Address to 208.67.222.222 or 208.67.220.220
1. Start run type cmd type ipconfig/all/ please give details. ( when connected to Internet and surfing ok )2. What is the modem number of your Linksys wifi router ?3. Are you using any separate modem given by MTNL ? model number.4. The OS in your computer.Para Two: Try in computer : Network/Lan/properties/ TCP/IP properties select assign IP address automatically. Enter open dns . Check Wireless Network available.
make sure you have enabled DHCP in your modem/router.. go to the modem/router's configuration page (192.168.1.1 is the default).. then look for an option called DHCP.. and enable it if it is not so!!
Facing a similar problem . iPhone 4 . Mtnl wifi not working. Wifi working on ipad/ laptop etcRequest help. Please explin in simple terms, i do not understand dns etc
