Will BSNL FTTH give me jittering in pings? Is it a healthy connection for gaming?
  • Thread starter Thread starter Al Pacino
  • Replies Replies 66
  • Views Views 18,585
It is fine now but there are spikes daily 5-10 times for a few minutes.
Contact your NIB.
Code:
C:\Users\SAHIB-LTP>tracert 13.250.61.32
Tracing route to ec2-13-250-61-32.ap-southeast-1.compute.amazonaws.com [13.250.61.32]
over a maximum of 30 hops:
  1     *        3 ms     *     DD-WRT [192.168.1.1]
  2     5 ms     4 ms     2 ms  192.168.1.251
  3     3 ms     3 ms     5 ms  103.194.144.1
  4     4 ms     3 ms     4 ms  218.248.168.225
  5     3 ms     3 ms     3 ms  static.ill.218.248.58.254/24.bsnl.in [218.248.58.254]
  6    89 ms    19 ms   101 ms  218.248.235.197
  7    17 ms    16 ms    17 ms  218.248.235.198
  8    16 ms    33 ms    23 ms  115.113.165.93.static-mumbai.vsnl.net.in [115.113.165.93]
  9    42 ms    42 ms    42 ms  172.17.169.202
10    79 ms    79 ms    78 ms  ix-ae-4-2.tcore1.cxr-chennai.as6453.net [180.87.36.9]
11    78 ms    79 ms    78 ms  if-ae-13-2.tcore1.svw-singapore.as6453.net [180.87.36.83]
12    79 ms    80 ms    79 ms  180.87.12.26
13     *        *        *     Request timed out.
14     *        *        *     Request timed out.
15    77 ms    76 ms    77 ms  52.93.10.63
16    73 ms    73 ms    73 ms  52.93.10.237
17    74 ms    74 ms    73 ms  52.93.10.234
18    74 ms    73 ms    74 ms  52.93.9.117
19    74 ms    74 ms    74 ms  203.83.223.77
20  ^C
C:\Users\SAHIB-LTP>
1 1 ms 1 ms 1 ms 192.168.100.1
2 3 ms 2 ms 2 ms 0.0.0.0
3 3 ms 2 ms 2 ms static.jullandar.bb.59.90.68.1/24.bsnl.in [59.90.68.1]
4 4 ms 2 ms 2 ms static.ill.218.248.56.82/24.bsnl.in [218.248.56.82]
5 4 ms * 4 ms 218.248.235.129
6 * 3 ms * 218.248.235.130
7 3 ms 4 ms 3 ms 115.110.232.45
8 40 ms 39 ms 39 ms 172.29.251.34
9 39 ms 39 ms 39 ms ix-ae-4-2.tcore2.CXR-Chennai.as6453.net [180.87.37.1]
10 72 ms 73 ms 84 ms if-ae-10-2.tcore2.SVW-Singapore.as6453.net [180.87.37.65]
11 73 ms 72 ms 71 ms 180.87.15.206
12 * * * Request timed out.
14 72 ms 79 ms 73 ms 52.93.10.57
15 73 ms 71 ms 71 ms 52.93.9.61
16 74 ms 71 ms 71 ms 52.93.9.38
17 71 ms 71 ms 71 ms 52.93.11.83
18 73 ms 71 ms 72 ms 52.93.11.90
19 73 ms 72 ms 73 ms 52.93.9.139
20 71 ms 71 ms 71 ms 203.83.223.19
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Do you have a static IP?
The IP is dynamic but it does not have a double NAT. So basically BSNL has a block of IP addresses namely 103.71.112.230 /22 . Now these IP addresses are assigned to my society and users are allocated dynamic IP addresses from this pool whenever they restart their routers. So it is a public facing IP address but dynamically allocated. You can easily access your network from outside via that IP and also use a hostname to update your IP address if it ever changes. Free services like DDNS and noip can be used.
My IP starts with 103.194.xxx.xxx, is dynamic public IP and no double NAT. Only problem I have had is with the ONT device, I have to port forward and assign DMZ in ONT instead on my router even though I have disabled DHCP in ONT.
How does the whole BSNL FTTH connection work. Fiber goes into ONT then a ethernet cable into Router? I have not used FTTH before. Do I purchase ONT from bsnl right away or get it on rental bases? I have a TP-Link archer c20 ac750 router, should I buy a gigabit router if I am applying for a 100mbps connection
Correct, fiber goes in ONT and Ethernet cable from ONT to router. You will get ONT free for the duration of your connection but they will keep 1 month rent as security deposit, Rs.500 for installation and Rs.500 extra if you want a landline. You won't get full 100mbps anyway so I think that router will be fine, I get max 36mbps on 40mbps connection.
