hiI am planning to import 42' LCD TV from usa. The issue is that I am confused whether it will work in india. The standard in india is PAL but USA follows NTSC.let say if i connect it to d2h(videcon) service which av inputs,then will it work on that. As signals would be PAL(india supported format)and I would be having ntsc tv.or is there any problem if I completely switch to digital solution. for example I buy HD box from Tata Sky and connect it to my HDTv.
