XZ000-G3 v1 with JioFiber UL speed slower
dcosmopolitan
Bangalore
JioFiber
Airtel Xstream
Hi, as seen in the forum I was able to setup G3 v1 for JioFiber connection with Archer AX10 router.
The problem is that I'm getting slower upload speeds. My plan is 300 Mbps.
I have tried both czech and brazil firmware for G3 v1.
Download speeds are reaching my plan speed 300 Mbps but upload is fluctuating between 150-250 Mbps no matter what.
Is this is a limitation of the setup or G3?
I have a 1 Gbps connection and XZ000-G3 v1. Do not believe the speedtest.net or fast.com bandwidth tests. Try the Azure download and upload speed test, then only you will know the actual bandwidth.
Facing the same issue on G3-V2 just set it up today. Is there any fix or workaround to increase the upload speed.
my G3-V2 - comes with FIrmware version 3.14 build 230129 Rel.6803n . There are risks invloved in updating firmware. As not sure what other issues may come up. So iam skeptical especially with Jio Fiber. Also i would be more comfortable doing this if i have a backup of my existing firmware.
