Nope that is not true. Although when you call CC for activation they may first try to suggest that they will add it as a 2nd box in addition to the new one. You just need to say that u need the new HD box as your main one and do not need the existing one.
I got it activated just now. For me they took the digicard from the old box and put it into the new one and the backend then enabled it on the HD Box.
They also asked a coupe of times if I needed the old box. I said i do need it
My dear friend, either you were lucky or they have changed policy just yesterday. Or you have been duped, check to see if you have same old subscriber ID or has it changed ? also the new HD STB monthly rental of Rs 150 is waived off for the 1st 2 months, so check your invoice the 3rd month if they have charged you for an add on connection. I've posted my ordeal in this forum before on this topic, and here it goes again:
I had 3 connections before I ordered tskyHD, 2 of which was active, and 1 was dormant. Since tskyHD was not available in any kolkata store, I ordered it on tsky helpline IVR, they checked my record and asked me if i wanted to retain any of the 3 connections. I told them very clearly that I dont wanna retain any of my old STBs and wanna replace them with the new HD boxes. So they acknowledged and took the order.
After 2 days the tsky engineer came home with two new HD boxes, I helped him install them since I got a complicated setup at my place, then during activation he communicated with someone through his cell phone and then told me that only one HD box can be activated as under once subscriber ID at the max 4 boxes can be activated, this my old 3 boxes + 1 new box = 4 box. I told him that I had ordered to drop all my existing boxes and replace them with the new ones thus making one of the HD box my primary connection. He spoke to helpline, made me speak, still the same thing, they said they can drop the 2 add-on connections but cant drop the primary SD stb undr my ID and that the HD boxes has to be add-ons only. I asked to escalate the issue then and there, he then contacted his chief engineer, who was very stiff in his language, and told me the same thing. He gave me an option of creating a new ID for the 2 HD boxes and closing the old ID alltogether which I could not do since I had over 2k in cash balance + 6 mths of super saver pack left. I told him that this information was not their on their website and neither I was told of this when I placed the order over their IVR and that I can take them to court for this duping. He was rude and said he cant help me and this was the rule, so I had to opt to retain one olf STB and take the new ones as add-ons. He asked me to pay his engineer in cash after the discussion and before my HD boxes were activated, I refused for the same, I told him that get it activated and take the money. He said you would have any way paid cash if you would have bought it from a store, I replied thats the reason I did not buy from the store directly. So he told the engineer to take out the installed boxes from my system and then come back again later, I told them they that I wont allow them to touch anything, and neither I have the patience and energy to go through all the physical labour of of uninstallation & reinstallation again. So the engineer left my plase with a promise to return in 5 hrs and that I will have a call from tsky HO. After an hr I got a call and was informed of the same options again, and I once again was made to go in for addon as I had no logical options. After 5 hrs the engineer came and then he activated the system, I paid him the money and he went away.
