ABC Analysis
Past few months I'm facing this peculiar problem of STB hanging. To describe my problem, no matter on which channel I am at and say I press the channel info button or chanel change or the volume button on my remote, the picture freezes and then none of my remote buttons are functional nor is the STB, even the power button does not work if I have to switch off the STB. The only option left for me is to switch OFF / ON the main switch (power cycle). The problem is solved, but then after a few hours again it happens. The frequency is around 6-7 times a day.Can you please let me know if you guys are facing or had faced in the past the same problem?What is the reason for this and the solution?Please let me know.
