ZTE AC2766 Error no device or device not ready to work confirm and retry later
  • Thread starter Thread starter ajaystvoo
  • Replies Replies 12
  • Views Views 7,726
Status
Not open for further replies.
recived new zte ac2766 from ebay for 1000 and its not working
can't open with sim dashboard
check on 2 pc
tried 10 time then after that install driver
after that error no device or device not ready to work confirm and retry later
please help just recharge 2 days evdo pack so limited time
probably usb connection problem because of that driver is not installing
recorrection looks like thats not the case
with sim can't open dashboard or software
without sim dashboard is working
tell me if other zte users are geting error too
main problem is with sim i am getting this error
please help
Tell me Your email I will send you zte ac 2766 working software !
sorry for late reply , I sent you ZTE AC2766 software Dashboard , It will surely get installed these time , But do remember that after installation just restart your pc then only open ZTE AC 2766 UI .
No , these isn't problem with your SIM or datacard , usually these happen due to driver problem and it do happens to me also ( I have two zte ac 2766 datacard and even have zte MF190 , D-Link DWP 157) , All of these have same problems, I thinks , whenever these error comes just reinsert the device and it will work .
Solution to the problem : You need to use " safely remove hardaware and eject media then click on ZTE FFF1 then these problem will rarely occur ).
or You could use windows dialer rather than standard UI of zte ac2766 .
just like you said i started installation
in installation datacard required
to be inserted to complete installtion
with sim inserted in dongle
my data card is no recognized by pc
during installation this error
1-http://s4.postimg.org/va9o67y9p/image.jpg
after waiting this error
2-http://s22.postimg.org/bm8sp9chd/Capture.jpg
after ejecting just like you said still not working
@ajaystvoo : Is you antivirus software enabled , If yes then please disable or uninstall it as it will detect your datacard as virus ( unlocked datacard usally are fasle positives ) . Later after installation of UI software you could re install your antivirus as mine antivirus detected mine Datacard content as virus . Second thing ,Have you updated your drivers , if not then please install iobit driver booster and update all your driver ( free version will work fine ) .
If it still isn't solves your problem, we could meet via team viewer , Tell me when You want to meet me .
Status
