Hello everyone ....
I got a strange but serious problem regarding connecting to BSNL via ethernet cable ....
WI-FI is working fine .... In fact i am posting this thread using wi-fi itself ....
but due to hardcored mesh of wires in my colony .... magnetic field intensity is too high and causing interruptions in my wi-fi ....
so i cant rely using wi-fi (except in emergency cases like present) ....
My modem is Nokia Siemens Residential router 1600 ....
Earlier i used to manually connect my BSNL till it spammed me with error 651 for 3 or 4 days .... then i called up junior engineer of BSNL and he just made my internet work through WI-FI and went saying,"Your LAN card is burnt"
he did nothing on my laptop except checking "ping 192.168.1.1" in command prompt and opening modem settings and enabling my wi-fi ....
then i got my laptop for a repair and that guy checked my laptop and told,"laptop is ok, Are you using BSNL ?"
i really could not stop laughing about his guess, but still he told me to change TCP/IP4 settings like
IP : 192.168.1.43
Subnet Mask : 255.255.255.0
Default Gateway : 192.168.1.1
DNS : 218.248.255.196
alternate DNS : 218.248.255.194
well these settings worked like a magic charm and i got access to BSNL via LAN .... but again since last 5 days im stuck with it .... not connecting via eternet cable ....
Tried : 1. changing TCP/IP4 settings ....
2. Resetting modem and configuring it again .... PPPOE ....
3. Enabling/Disabling Local Area Network ....
4. uninstalling and re-installing my nvidia nforce network adapter ....
5. Enabling DHCP and auto IP addres and DNS acquisition ....
result : FAILURE :/
I know many of you will suggest to change ISP and even i would had done it long back .... but no other LAN based (wired) broadband available in Rupnagar (Ropar), Punjab.
so please it will be helpful if someone can solve it ....
P.S. : I am able to access internet of HFCL (connect telecom) at my friends place using same laptop.
Local Area Network status :
http://imageshack.us/photo/my-images/209/statusez.png/
IPCONFIG command result in command prompt :
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
Windows IP Configuration
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Wireless LAN adapter Wireless Network Connection:
Link-local IPv6 Address . . . . . : fe80::8878:1fa5:ac65:c739%13
IPv4 Address. . . . . . . . . . . : 192.168.1.3
Link-local IPv6 Address . . . . . : fe80::b4d8:ff96:3a64:9988%11
IPv4 Address. . . . . . . . . . . : 192.168.1.43
Tunnel adapter isatap.{F4E8F1C1-D19E-4596-9617-2F42B975D1B8}:
Tunnel adapter isatap.{EE0ECE0D-5490-41BF-874B-E2FCC1CF06F6}:
Tunnel adapter isatap.{0F506FEB-2B6C-49FD-A03D-77ACE05D273F}:
IPCONFIG /ALL result in command prompt :
C:\Users\gill>ipconfig /all
Host Name . . . . . . . . . . . . : gill-PC
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 00-1A-6B-86-FE-99
DHCP Enabled. . . . . . . . . . . : Yes
Description . . . . . . . . . . . : Broadcom 802.11 Multiband Network Adapter
Physical Address. . . . . . . . . : 00-1A-73-60-E6-D5
Link-local IPv6 Address . . . . . : fe80::8878:1fa5:ac65:c739%13(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.3(Preferred)
Lease Obtained. . . . . . . . . . : Sunday, August 19, 2012 4:51:40 PM
Lease Expires . . . . . . . . . . : Monday, August 20, 2012 4:51:39 PM
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 218110579
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-C3-2C-28-00-1B-24-58-85-FD
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-1B-24-58-85-FD
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::b4d8:ff96:3a64:9988%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.43(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 234887972
DNS Servers . . . . . . . . . . . : 218.248.255.196
218.248.255.194
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
IP : 192.168.1.43
result : FAILURE :/
Hide Hack By
vFCoders.
C:\Users\gill>ipconfigvFCoders.
218.248.255.194
