A strange problem with BSNL via ethernet cable ....
  • Thread starter Thread starter Teji Gill
  • Replies Replies 42
  • Views Views 14,108
your driver software is corrupted..Before that
Install kaspersky run full scan see if you find some thing.
My goodness. You can actually understand the COMBOFIX.TXT log?
Try changing modem port say lan 1 to something else that is availale backside of your modem.Eg: If it s lan1 change to lan 2@uberjonnot much what else could be the problem? It s lan card/driver fault or some spyware playing hide and seekI m on cellphone sorry for multiposting
@x720 done some 4 to 5 times but useless :D@uberjon right .... i will try bridge connection now ;)@chin hmm i also smell same now .... used Malware bytes, Microsoft malware removal tools .... but they dint gave any proper results .... but registry tweak Ccleaner gave me 2261 errors in first hit :p nvm i repaired registry using Windows Registry Repair tool .... now i am about to scan my system with Kaspersky Internet Security Pro, Bitdefender pro 2012 .... after that i will try on Norton also .... There must be only some spyware because i tried changing MAC address also and it did not helped me ....i got to know from a friend that Microsoft .Net Framework also causes such problems sometimes .... lets see if scanning is helpful .... or i will completely format my laptop after making backup of some essential files .... :)will let you know results .... good or bad :p whatever they will be ....but yea that Combofix is good for only complete windows 7 not for light version of windows .... i needed to opt system restore as Combofix had bugged mine everything .... I was not able to open any *.exe file .... Once i thought i'm screwed without backup :p
Did it work?
Can you ping 192.168.1.1?
Can you post your ipconfig again?
Code:
ipconfig/all
problem solved im using ethernet cable now ....issues was : 319 Spyware, 2261 Registry Errors and 11 Malware :pCcleaner took care of registry errors ....Malware bytes took care of malware ....Kaspersky and AVG took care of spyware .... installed them 1 by 1 and scanned my system ....thanx chin, uberjon for help buddies :D-------------------------------------------------Here is new ipconfig /all results :Microsoft Windows [Version 6.1.7601]Copyright (c) 2009 Microsoft Corporation. All rights reserved.C:\Users\gill>ipconfig /allWindows IP Configuration Host Name . . . . . . . . . . . . : gill-PC Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : NoWireless LAN adapter Wireless Network Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Broadcom 802.11 Multiband Network Adapter Physical Address. . . . . . . . . : 00-1A-73-60-E6-D5 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : YesEthernet adapter Local Area Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : NVIDIA nForce Networking Controller Physical Address. . . . . . . . . : 00-1B-24-58-85-FD DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::b4d8:ff96:3a64:9988%11(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.43(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 DHCPv6 IAID . . . . . . . . . . . : 234887972 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-C3-2C-28-00-1B-24-58-85-FD DNS Servers . . . . . . . . . . . : 218.248.255.196 218.248.255.194 NetBIOS over Tcpip. . . . . . . . : EnabledTunnel adapter isatap.{EE0ECE0D-5490-41BF-874B-E2FCC1CF06F6}: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : YesTunnel adapter isatap.{F4E8F1C1-D19E-4596-9617-2F42B975D1B8}: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3 Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : YesTunnel adapter Teredo Tunneling Pseudo-Interface: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : 2001:0:9d38:953c:8e4:3ae3:3f57:fed4(Preferred) Link-local IPv6 Address . . . . . : fe80::8e4:3ae3:3f57:fed4%17(Preferred) Default Gateway . . . . . . . . . : :: NetBIOS over Tcpip. . . . . . . . : DisabledC:\Users\gill>
That's great news!Advice: You must have ONLY 1 antivirus on your system. Please remove AVG or Kaspersky.Glad everything is fine now!
I dont think this thing going to leave me so easily ....AVG asked for restart .... and again same problem .... not able to connect via ethernet ....WTf is going on :(
