acerpure Pro Air Purifier for Home, 4 in 1 HEPA filter with 4 layer protection, Smart Sensor, Negative Ion Generator eliminates pollutants, germs, bacteria and more, Safety Lock, 25dB Quiet, AP551-50W
acerpure Pro Air Purifier for Home, 4 in 1 HEPA filter with 4 layer protection, Smart Sensor, Negative Ion Generator eliminates pollutants, germs, bacteria and more, Safety Lock, 25dB Quiet, AP551-50W | Acer India Official Store
Smart App : acerpure Life - Supported by a brand-new App and Google Home, detecting the indoor air quality, and sending automatic notifications of
outdoor air pollution alerts. Able to control, monitor, and start the air-purifying functions even you are not home. CADR (Clean Air Delivery Rate) : 324 CMH.
4-in-1 HEPA Filter, Four-layer Protection : Take control of your air quality with the 4-in-1 HEPA filter and eliminate up to 99% of airborne bacteria, 99.97% of ultrafine dust, PM1.0, and allergies. Against Viruses with HEPA Plus+ : Effectively eliminate 99.99% bacteria, 99.9% anti-coronavirus (229E) 2 and influenza A (H1N1)3 virus activity. The HEPA Plus+ has been certified by the 3rd party research center. Pre-Filter, HEPA Plus+ Filter (Anti-virus & anti-bacterial layer), HEPA 13 Filter, Activated Carbon Filter
Low Energy, High-Performance : with a DC motor, expect high performance of purification at a low energy cost. Quite Mode : Reduced noise and turned-off display make for the perfect environment for a good night's sleep. Safety Lock : It comes with safety lock , so you don't have to worry about the mistaken touch by children and pet.
High-Efficiency Purification : The acerpure pro delivers filtered fresh for you, makes you always can take a deep breath.
10 Million Negative Ions: Effective Purification : Fill your home with a high concentration of negative ions, capturing ultrafine dust and PM1.0, Smart Sensor & LCD Display : Put your feet up as the Air Quality & Gas Sensor regulates the purifier speed automatically and LCD displays real-time air quality data.
1 Year Warranty
Country of origin : China
