Im thinking of upgrading my 220 BX modem with 450 BXi router.
Does IPTABLE work on 450 BXi ?
Yes netzzz,
The 450 Bxi is a good router. It has more features that the 220. I suggest you upgrade.
This is also a linux based router iptables works. You can also web browse to access the settings too. Airtel has some sort of auto config option, when your router logs in and connect's to the internet, the advanced settings disappear in your router.
I messed around with the settings and figured a way out to prevent this from happening. More on this later...
Yes netzzz,
