What part of the wire have they changed? Is there any bleeding of the signal in b/w the exchange to your place? I think they have methods to determine these kind of faults. Contact the CC again with your problem, they'll get the line checked and solve your problem.
Hi Apoorv, thanks for reading my thread and replying
, I am not sure what part of the wire they have changed, the broadband engineer will arrive in a few mins to determine the fault, will ask him, what part of the wire has been changed.
Line attenuation is rather high, but nothing exceptional.
Your problem is definitely from the back end.
You could double check if you don't have parallel phones which are not filtered.
The splitter/ filter should be used on direct line and then phone output should be made parallel. Once you have ensured this then get after Airtel to sort your issue out.
Some cordless phones may also create problems with DSL. Disconnect any cordless phones and then see if connection drops ( or remove phone altogether)
The more you try the more you will narrow down to the exact cause.
Hi there,
Mac!
. thanks for replying to my post. Well, after lodging many complaints to the airtel helpine (121) I was told it would be checked if the problem is there in the backend. Yes I have checked the splitter is used on direct line and then phone output is made parallel. don't have a cordless phone. I have called up 121 y'day again and the broadband engineer is supposed to come today, to check the problem again.
The first thing to check is whether your
ADSL line is going down or not when you have this problem. Have a look in your modem logs to see if this is happening. Let me know and we can proceed further with troubleshooting.
Also, are you having this problem from both the wireless
laptop and from the desktop PC?
hey there, Coimby. thanks for reading my post and replying. Yes I am having this problem from both the wireless laptop and from the desktop. though after the old copper wire has been replaced by the new one, the disconnections are few and the Dsl light in the modem ( yellow) doesn't flicker when there is a disconnection, but stilll I have a few disconnections. and how do i check whether my ADSL line is going down or not when I have this problem? where are the modem logs located?.
Hey Apoorv, the broadband engineer just arrived at my home to determine the problem, and upon asking what part of the wire has been changed he said " the whole wire from the exchange to the box in your house and from the box to the splitter has been changed and also the line has been checked using a test called SULIM test to determine the quality of the line". and also the INSTRUMENT was replaced by the engineer.
update : the engineer checked the SNR numbers too, and it was around 18, and then he said he will check the line again because he according to him it should be around 25-26 only then it would be considered "good". anyway, I am posting the snr margin screen grab here again,
well, i thought I should post the result of my internet connection speed test.
note : current broadband plan : 512 kpbs daytime and 1 mbps night time, my system has latest version of java runtime environment, all active downloads and browser
windows were closed before beginning the test, since the speed test may show inaccurate results with a WiFi connection, I made sure my computer is connected to the ADSL modem/
router with the Ethernet cable. the time at which this test was done : around 5 pm, sept 12, 2009.
