vidurchhabra
Okay Admin, thanks to your inputs, I am ready to take a plunge into Airtel IPTV.Currently I have home 999 (past 3-4 years), which is 384 plan, and I was planning to upgrade anyway to 1 Mbps or 512kbps, so the IPTV plan 1599 seems sweet.However I would appreciate if you could answer a few of my queries:1. My prime concern is broadband speed (I already have Tata Sky). There are some reviews which have mentioned degradation of speed. Are you getting consistent speed on the 512kbps, I guess downloads of around 60Kpbs?2. How good is the range of the inbuilt wifi in the set top box? Can I extend the range through repeaters or additional routers? Basically I need the range to run both on my ground and first floor (my Netgear wifi does the job well right now)3. Do we have FUP for broadband in IPTV?4. Are there any issues on time lag while switching between channels, how would it compare to a tata sky? I would imagine a time lag being a bit frustrating5. Can we add additional TV's like in DTH?6. Is the Electronic Program guide really quite bad, compared to say again Tata Sky?7. Finally, are you completely satisfied with the service right now, as far as judders, smoothness of the moving picture etc. are concerned?Thanks, and look forward to your opinion soon.
