Alexa Voice Remote Pro
  • Views Views 877
“Alexa, find my remote.” – Use a device with Alexa, the Alexa app or Fire TV app and Alexa Voice Remote Pro will emit a ring. No searching cushions.
Backlit for your convenience – Navigate movie night with a motion-activated backlight that illuminates buttons in dimly-lit rooms.
Two customizable buttons - Create your own shortcuts to favorite channels, apps, or any Alexa commands.
Dedicated headphone button – A new shortcut to the on-screen Bluetooth menu that lets you pair your wireless headphones fast.
Integrated TV controls - Control power, volume, plus surf live TV with dedicated channel buttons all from one remote.
Press and ask Alexa - Use your voice to find your shows, open apps, manage volume, and even control compatible smart home devices.
Compatible with most Fire TV streaming media players - Fire TV Stick Lite, Fire TV Stick, Fire TV Stick 4k, Fire TV Stick 4k Max, Fire TV Cube and most Smart TVs with Fire TV built-in.
Alexa Voice Remote Pro—Remote Finder Feature, Customisable Buttons, and Backlighting for INR 2,499
Alexa Voice Remote Pro is a new premium remote built to help customers spend more time streaming and less time searching for the remote, and is compatible with most Fire TV streaming media players, and Smart TVs with Fire TV built-in. It introduces a Remote Finder feature to help customers find misplaced remotes more easily. Simply say, “Alexa, find my remote” or use the dedicated Remote Finder button in Fire TV app, and Alexa Voice Remote Pro’s built-in speaker will emit an audible ring to attract your attention.
Two new customizable buttons make getting to your favorite content and Alexa commands quicker and easier. You can personalize your remote by programming these buttons to create one-touch shortcuts to favorite apps, channels, and anything Alexa can do. For example, you could choose to program a button to have Alexa dim the lights, check the weather, or start an Alexa Routine for movie night. Alexa Voice Remote Pro also includes motion-activated backlit buttons that automatically illuminate when the remote is picked up in low-light settings.
