Amazon Ring Car Cam
  • Views Views 1,133
Introducing Ring Car Cam, a first-of-its-kind security camera for your car that helps protect you and your vehicle regardless of whether you are driving or parked. This car security camera is full of features that help keep you, your loved ones and your car safe. Similar to Ring Car Alarm, when your car is parked, the sensors monitor for bumps and attempted break-ins, sending a real-time alert to the Ring app. With its dual-facing HD cameras, you can see a live view and check-in on what’s happening in and around the vehicle from anywhere over wifi or LTE (with an optional connectivity plan).
While driving, it keeps you and your loved ones safe with features like Emergency Crash Assist, which will automatically request help from first responders if a serious crash is detected.
Ring Car Cam will also include a new feature called Traffic Stop. If you’re pulled over while driving, simply say, “Alexa, I’m being pulled over,” and your Ring Car Cam will automatically start recording. Footage from the stop will be securely stored, and you can automatically notify a loved one a notification of the stop. Ring Car Cam will be $199.99
