Any diy solution for ac smell problem?
  • Thread starter Thread starter Smh
  • Replies Replies 15
  • Views Views 3,172
Smh
Delhi-Hyderadbad
Local-
ACT-
AirtelFiber
I got it serviced few months ago, they cleaned with water pressure thing. (Unit was not removed)
Earlier I tried a diy foam cleaning thing but it only changed the musky smell to weird LPG gas smell for few days.
All foam solution has bad reviews if you had any success, please suggest.
So after running it on fan mode somehow I managed to get rid of the smell.
But I guess it happened because Ice starts forming and compressor keep running without stopping.
I don't know if it's because of humidity. Only way it works properly is when I run it on humid mode.
Anyone else in Delhi right now facing ac issues because of humidity?
I believe ice formation is due to low gas levels?
Do find the source of leakage before topping up gas as any money spent on refill would be waste.
Yes, ice formation is due to low gas levels. @Smh Is there an open drain near the place you are living?
@mikrotik yeah that drain gas issue is present in this area.
I will get it checked for gas issue.
Since the normal warranty is over now. Should I call the company guys or local ones. Tbh both installer and service company guys were not extra 'professional' in terms of expertise or tools.
If you have such issue in your area, I would suggest you buying the Appliance protection plan of Urban Company. In that gas charging is included. And if your AC breaks down even once during the 1 year period then also you will be in profit.
