Anyone using Asianet Gigafiber Broadband
  • Thread starter Thread starter Sanemi
  • Replies Replies 8
  • Views Views 2,807
India
BSNL | KV | Asianet
Hi I'm thinking of getting the Asianet gigafiber broadband direct from Asianet side . Their plans are attractive for 1999+GST you will get 3 months of 200mbps (3000GB) internet and free installation. But I'm worried about their service and downtime. Anyone who is using please give me a review or suggestion.
Place : Angamaly
@coolsam07
@varkey
@rtr00t
@steam
@Ameen
@Lucifer96
Yes I am using it for past 2+ years. I didn't faced any major downtimes till now except for a main road fiber cut , then also they will rectify it in 5 hrs . Speed wise for content streaming and all it's the best. International speeds are not the best as it is still a local isp .please check with user from your area for the accurate downtime . There is a dedicated telegram group with asianet user from all over kerala.
@Lucifer96 Bro When I asked Asianet, they said that they have pulled the cable to the front of the house but the service has not been started. Bro is the speed constant? . What's your current plan?. Can you also provide me the Asianet telegram group link
1. Speed is constant for me getting 165 mbps for 150 mbps plan. International speeds are not good. It again depends on area to area service.
2. I am having 6 months 150 mbps plan with free one month. So the comes down to 750rs
3. You can search for asianet broadband group. You can easily get it.
@atom4u I don't do gaming so I cannot really comment on it. But for the other use cases like content consumption pings are good . Also asianet doesn't really play a major role here as they rely completely on tata/airtel for transit.
