Attention: Dramatic Fall In Connection Speed
  • Thread starter Thread starter techiways
  • Replies Replies 23
  • Views Views 3,909
techiways
Hi,I'm experienceing fall in connection speed since 24 hours. Is there anyone els with similar problem. My connection speed has dramtically fallen to 64 kbps. The maximum download speeds i get is around 8 to 9 kb / sec. Moreover the connection is not constant. It gets jammed frequently that is halts to 0 kb for few mins every now n then.Anyone els experiecing similar problems or is it only me? I'm in tamilnadu and have been using home plan ul 900 since 3 months. This is the first time i've come across such problems. Any updates or follows regarding this will be greatly appreciated.Thanks
Yep ...me too ..I am feeling cheated by BSNL @!!! F :huh: what can we do.... guyz ...plz report in your status too !
hotindia > are you on ul900 plan? What speeds are you getting? Since when are you experiencing the problem?Others > Plz report your present connection speeds.
QUOTE(Globus @ Nov 4 2006, 05:45 PM) [snapback]67723[/snapback]
[/b]
Yes I've been experiencing this problem too.
HELP! What do we do?!? :(
me too was facing the same prob whole day....:(but now its back to full speeds after 6.00pm... :)
QUOTE(avinds @ Nov 4 2006, 07:00 PM) [snapback]67735[/snapback]
[/b]
Anybody else got full speed back? Because I certainly haven't.
i am on 900 plus plan my speed has risen again now i am getting normal speedsLast Result:Download Speed: 255 kbps (31.9 KB/sec transfer rate)Upload Speed: 62 kbps (7.8 KB/sec transfer rate)according to online speedtest
