Best Electric toothbrush?
  • Thread starter Thread starter dejan
  • Replies Replies 11
  • Views Views 2,501
are you able to find replacement brushes for your oral-b model? they seem to have totally disappeared from the market!
arey bhai. stop using quotes for quoting posts that is just above your response. :P if you are on g+ you can PM with me there. link is in my signature. :|
I'm also looking for a good hair spray if anyone could help me get it online
Need suggestions for good electric tooth brushes ..any leads? Also need flossing wire ..no damn medical shops near me has them
oral-b as mentioned above had refill problems with electronic toothbrushes. not sure if they fixed it eventually. :\
