Best Hand Sanitizer?
  • Replies Replies 156
  • Views Views 23,896
I have ordered Mediker Hand Sanitizer with mostly positive reviews from Flipkart. Yet to receive
All these 500ml bottles should come with a pump. Uncapping, lifting the bottle and pouring it on your hands is not only inconvenient but unsanitary too.
Almost all the bottles I have bought in the last couple of weeks... All have the same size top so you can basically interchange the top 😛
All of these companies be like use pea sized amount. I have to take two pumps full of solution to properly wipe both my hands.
I ordered the Dabur Sanitizer from Flipkart. It has a strong smell that lingers. I prefer Lifebuoy over it because of its faint smell.
It is available on Flipkart at the moment too. Flipkart has Savlon Sanitizer refill bottle available too but I've already ordered 2 litres of sanitizers. I don't think I'm going to need anymore for quite a while.
Ye bhi aa gaya. And this one also suggests using pea sized solution for both hands 👐
this has the same pungent smell that rubbing alcohol has.
