Best modem for UL1350 plan...?
  • Thread starter Thread starter Me again
  • Replies Replies 11
  • Views Views 2,198
Me again
None
Hi guys, I've finally decided to put UL1350 plan:dance:...Please help me choose the best modem.....im a gamer and mostly play online games...so,please give me some suggestions...
@me-again/
Google search
modem router for online games
If you get a modem/router with UPnP then it will open the ports you require without your input. D-Link, Dynalink, Linksys etc all have modem/router combinations that have UPnP that can be enabled or disabled.
Correct. I recommend the Billion 7100. Perfect for me and all the gaming I do.
have the WAG54G with firewall enabled.
Stable - Mine is never turned off, sometimes has to be restarted due to wireless dropping off but no problem with ADSL.
Have 15 single port forwards, 10 port range forwarding and 10 port triggering.
My son plays different games, Halo, Unreal Tournament etc on either desktop or laptop and I have never had to setup port forwarding. The only port I have opened is 3389 for remote desktop.
etc
Para two : Your speed 256Kbps 32KB/sec may not be suitable for playing games
May need a faster connection.
Is the UL1350plus plan with 512kbps bandwidth any good for online gaming.....?:huh:
@me-again/
Google search
etc
Im getting a seperate router to connect my xbox360,PS3,PSP,notebook and PC in my network.The router is D-Link DIR-655....Is it advisable to buy it..?
is the UL1350plus plan with 512kbps bandwidth any good for online gaming.....?
My mistake. If it is 512Kbps could be suitable.
speed has gone up to Max 512 divided by 8 64KB/sec .( usually not achieved)
If 2 Mbps connection Max 256 KB/sec Four times faster. ( Usually not achieved).
Please wait for feedback from gamers.
Para two:
http://www.dlink.com/products/?pid=530
Gigabit speed for Kbit broadband connection !!
U should forget about gaming with bsnl cos latencies are too high.
Even with 512kbps bandwidth...?....Is there anyother plans thats good for gaming..?
bandwidth and latency are different.. you might even hav a 2mbps connxn but if your latency is bad you'll have a horrible gameplay experience
