Bharat Fibre 449 enquiry
  • Thread starter Thread starter pudu123
  • Replies Replies 9
  • Views Views 1,125
pudu123
Regular
Delhi
Airtel Xtreme 40Mbps 499
I’m thinking of switching from spectra to bsnl fibre.
reason for switching is bsnl fibre is 50% cheaper.
my current plan is spectra basic unlimited which gives 50mbps speeds for ₹949+taxes.
bsnl fibre unlimited plan gives 30mbps speeds for ₹449+taxes which is 50-55% cheaper.
is bsnl fibre decent? Any downtimes?
It's totally understandable that due to costing one decides to change, however consider this.. You won't get stable internet speed, intermittent disconnections, customer support that's not so helpful as you are at the mercy of LCO..
And all this at the installation cost of Rs. 4500..
I had two options, Joister and BSNL.. Both sucked, BSNL seemed better but now it's the same..
Also.. that 50mbps at 499 is not applicable in all circles even if the portal shows it applicable to your state.. you need to ask your local BSNL office first...
@ginzon afaik installation cost is ₹500 + 1 month plan advance₹449) and ₹90/month rental if one decides to get the router.
speed is 30mbps.
I am also worried about downtime and frequent disconnections. This is the one thing which will be a deal breaker
That rental option is something of you don't wish to buy one, not sure it's applicable everywhere.. I didn't have that option..
The rest I've already mentioned..
Save the trouble, use spectra..
I’m probably going to stay with spectra. Will wait for Airtel or jio fibre to be available at my place.
Ha ha....dont let 1 person change your opinion :P
BSNL 449 Plan is value for money and what I have been hearing new plan is coming for Rs599 (60Mpbs)
BSNL Speeds are as per promised (yes few do face issue but generally everyone get rated speed)
Customer care is non existing but 1s complains is booked in system be it LCO or Exchange they have to attend it in defined SLA.
Fibre cut is different story
I am using 449 Plans....have not faced any downtime in last 2-3 months of my connection
LOC took 3K for Router + Installation
Only issue with him was he didnt had the power backup for his devices (as he was new guy)...waited 1 month for him to have the arrangement latter complained with BSNL and then he did the power back up in 2 days..
Speed is always above 30Mbps...always.
You sure are not from rural area 😂, like me 😭..
Also my exp is based on two connections, one here at my native place in Maharastra and one at Pune.. Pune is still better at speed but not at stability..
OP needs reliable connection and hence I suggested otherwise..
449/- plan is for first 6 months from date the of activation than it will automatically change to new 599(60 mbps) plan.
I'm from rural area and I mostly get reliable connection. Sometimes routing gets messed up for the whole north east region but those get fixes in 10-20 min later. Except those few hiccups I'm getting 100mbps consistently and kinda okay latency. Around 40ms to Mumbai and 80-90ms to Singapore.
It'd be best if OP asks others in his area who uses BSNL for their experience. The service really depends on location.
