Thanks, My card reader is running in the phoenix mode. i am using nftytool-1.1 to run the card in the phoenix mode, after running this nftytool the red light on the box starts glowing. I am using newcs for reading the card. I copied the newcs.xml configuration you had posted and i run the newcs newcs.i686. This is what it outputs,
TCP-log password is enabled, set to: NewCSpwd
level: internal
type: all
output: console,tcp
logger config: level 1 type 255 output 5
Console log options: level 1 type 255
tcp port: 1001
TCP log options: level 1 type 255
[ 11:07:29 ] [ Box detect ] Box type 1
[ 11:07:29 ] [ Config ] Option for device 0 (Phoenix on Com1) not present, defaulting to NO
[ 11:07:29 ] [ Config ] Option for device 0 (Phoenix on Com1) not present, no static sids added to filter
[ 11:07:29 ] [ Config ] /dev/ttyS0 ECM priority: round
[ 11:07:29 ] [ Newcamd ] Server name : newcs
[ 11:07:29 ] [ Newcamd ] Des key : 0102030405060708091011121314
[ 11:07:29 ] [ Newcamd ] User 2: dummy, Pass: dummy, Host none, Port: 0, Au: On, Spider allowed: No, Sidoverride: No, level: 1
[ 11:07:29 ] [ EMM Cache ] Initialising Cache with 20 entries
[ 11:07:29 ] [ ECM Cache ] Initialising dynamic Cache
[ NewCS ] Process ID is: 4183
[ 11:07:29 ] [ Loader ] Reader type 2 on node /dev/ttyS0
[ 11:07:29 ] [ Phoenix ] Opening device /dev/ttyS0
[ 11:07:29 ] [ Phoenix ] Setting Parity to: NONE
[ 11:07:29 ] [ Phoenix ] Setting Baud to standard 9600
[ 11:07:29 ] [ Phoenix ] Normal RESET on node /dev/ttyS0
[ 11:07:31 ] [ Loader ] Unknown card
[ 11:07:31 ] [ Loader ] Trying Irdeto (T=14)
[ 11:07:31 ] [ Loader ] Reader type 2 on node /dev/ttyS0
[ 11:07:31 ] [ Phoenix ] Opening device /dev/ttyS0
[ 11:07:31 ] [ Phoenix ] Setting Parity to: NONE
[ 11:07:31 ] [ Phoenix ] Setting Baud to custom 5713
[ 11:07:31 ] [ Phoenix ] Normal RESET on node /dev/ttyS0
[ 11:07:33 ] [ Loader ] Init Irdeto card
[ 11:07:33 ] [ Phoenix ] Setting Parity to: NONE
[ 11:07:33 ] [ Phoenix ] Setting Baud to custom 5713
[ 11:07:33 ] [ Keyman ] Adding key D2618D type 0 on Provider 0 for caid 0649 ID=0
[ 11:07:33 ] [ Keyman ] Adding key 15A998 type 1 on Provider 0 for caid 0649 ID=0
[ 11:07:34 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 1 for caid 0649 ID=1
[ 11:07:34 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 2 for caid 0649 ID=2
[ 11:07:34 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 3 for caid 0649 ID=3
[ 11:07:34 ] [ Loader ] Card 0649 on port /dev/ttyS0 ready
[ 11:07:34 ] [ Loader ] Starting Newcamd Server on port 10002
[ 11:07:34 ] [ Loader ] Starting Radegast Server on port 10001
[ 11:07:34 ] [ NewCS ] Ready to GO!
Should i use any other application like Wincs what you have mentioned for
windows application? Is there any similar application for linux? Actually i am playing the video on VDR application. i am trying to stream the singals to VLC and play in it. So i need to descramble the signals.
I tried playing directly on VLC but only FTA channels are being played, How do i play non FTA channels on VLC directly?
Thanks,[COLOR=\"Silver\"]
[/COLOR]hi I am using libvdr-sc.so.1.7.4 plugin along with vdr, but when i try to stream to VLC it is not playing, on the message window of the VLC i get a warning message saying
Invalid header received, this i assume because the channel is scrambled.
Thanks,
hi,
here is the alternative software combo that i think should work for linux:
1) replacement for Progdvb - VDR
2) replacement for WinCSC - use the appropriate softcam plugin, there is one for VDR that i know exists; here is the link to its README file:
https://opensvn.csie.org/traccgi/sascng/browser/sc/PLUGINS/src/sc-src/README?rev=38
Please note, the VDR plugin can also directly work with your smartcard thus bypassing the need for newcs, but since you already got newcs working with your smartcard, you can just use the VDR plugin in "cardserver client" mode. i.e, the VDR plugin will act as a "cardserver client" and talk to newcs which is running as a "cardserver". check the link to the README posted above for more details.
3) replacement for newcs: not needed, newcs works on a lot of platforms, including windows and linux both.
NOTE: the link posted above is for a softcam plugin for VDR, if you wish to use a different viewer, like mythTV or Kaffeine or VLC or your own favorite viewer, you will have to hunt around for a softcam plugin that works with that application. I did not spend time on trying to get the setup working on linux, so I cannot give you detailed steps, but If you do manage to get stuff working on linux, please do post the same here for the benefit of other users.
Also, my strong suggestion is to try and get the stuff working with VDR first, then you can explore the possibility of using some other viewer.
