S
ssvinayd
hi ppl
u can also join using internet
Hub Name : Hê@vÝ M€']['ÅL hµßß
Hub Addy : 172.19.1.200:411
Hub Email : [email protected]
Hub internet address : thaneheavymetal.zapto.org (only 4 registered users )
Hub internet address : bhandupheavymetal.zapto.org (open 2 all users )
Hub internet address : sionheavymetal.zapto.org (open 2 all users )
MinShare : 1 GB
MinSlots : 3
i run a dc++ lan hub used 4
sharing exchanging & softwares songs movies & games
over lan u can also join the hub
by using the software dc++ or czdc++
downlod this software 4m my comp i had shared it
& just use the hub ip 172.19.1.200 to conect 2 me
but b4 that u need 2 do some settings in ur ip address
go to my network places -> rt click -> properties -> local area connection ->
rt cick -> properties -> tcp/ip -> properties -> advance -> add ip address
IP ADDRESS : 172.xxx.xxx.xxx
Subnet Mask : 255.0.0.0
where xxx = 001 to 254
u can put any no. in this range
then just go on clicking OK till it close
then run the software czdc++
then go to files -> setting -> general -> & put ur nick name watever u want
then in click the red heart in that u can see teh heavy metal hub
rt click properties & out ur nick there also & then conect 2 the hub
u can share ur stuff by go in setting -> sharing & ther u can add ur folder or
drive 2 share so that every 1 can get ur data
mail & chat with me on [email protected]
download czdc++ or dc++ 4m net or my pc & use it 2 conect my pc at ip 172.19.1.200
orkut comunity - http://www.orkut.com/Community.aspx?cmm=19125993
MinShare : 1 GB
MinSlots : 3
Download CzDC 0.699[D1]
Download CzDC - An alternative to DC and a peer-to-peer file exchange tool that is straightforward to use and that can increase transfer speeds for Direct Connect
www.softpedia.com
