Bsnl Broadband 4mbps plan but getting only 1mbps speed why?
  • Thread starter Thread starter Ace Charles
  • Replies Replies 13
  • Views Views 4,416
I think you should get it changed to 6144 Kbps so you get true 4 Mbps speed as aatuif mentioned above. I also have it at 4096 Kbps, getting around 3.4 Mbps. Will be requesting the same from BSNL office soon.
I Complained on pgportal and local engineer said they cannot increase it above 4000 kbps. They said if they increase the downstream they will have to decrease the upstream which is 494 kbps.I even showed them this forum and how people from other states have got their downstream increased.They even told me if u want it changed u have to go for higher plan.I told them to increase to atleast 4096 and they said increasing to that wont make difference to speed I am on 845 combo plan Getting around 3.4 mbps in speedtest c o m Do They change the downstream as per ur plan? If i complain on facebook or twitter again they direct the problem to the same engineer
Thanks for the heads up, the difficulties of being on BSNL network. Let me check up with Engineer here in Cochin, Kerala, if same response.
man they will not increase port profile. to higher plan. to get it changed change plan to a 8mbps plan. and then contact local exchange. then change plan to a lower plan by tweeting to them.
