Siemens c2110 not working blinking cont.. Please help on this problem.
my modem warranty has been expired
I have a problem with my Siemens C2110 ADSL modem. The LEDs on the modem is blinking always. I turned on the modem while the PC is off and the phone line disconnected, then all the LEDs turn on, which should not happen as only the power LED (the red one) should be on and all others off until I connect the LAN cable. And if I connect the LAN cable and turn on th PC, the phone line still disconnected, then all the three LEDs (except the power LED) begins blinking continuously. I tried resetting the modem but it didn't solve.
I can ping 192.168.1.1 but cannot open it through IE or Opera. So I cannot access the modem settings. Is there any way to solve the problem like flashing the firmware or is my modem out-of-order.
hello all,well i resolved my problem by getting a new ZTE ZXDSL 531B from BSNL. i had to buy it since my modem's warranty period was over n i was getting frustrated over accessing the internet through my mobile... @mixmaxi don't know much but i think i can safely say that if u can access 192.168.1.1 then u r not totally gone...there's still hope. i'd suggest that u call customer care...they would come over even if the warranty period is finished...i think its probably a configuration problem...just a guess....
please give deatailed information
which software are you chosen and
what is the"serial port of the player"
please give more detail throgh forum or my mail
tmsafeer@gmail.com
tmsafeer@bsnl.in
hi, I tried upgrading my firmware with a new img file but while upgrading the power failure occured and now the modem is not getting detected. please help me in this issue thanks
thanks
Start RUN cmd OK
Telnet
type 192.168.1.1
do you get log in ?
Please mention what is the problem.
If able to access the modem menu pages
first 192.168.1.1 ID admin PW admin or password ( default)
Then 192.168.1.1/look.html
Ignore the fonts.
COPY/PASTE Data here.
Needed to suggest Firmware upgrade.
See this recent post :
