BSNL Broadband: Help me in finding latest firmware for Nokia Siemens SL2_141 ADSl Wireless Modem
  • Thread starter Thread starter coolday
  • Replies Replies 18
  • Views Views 21,617
I checked up the "Sticky" thread as mentioned. But not able to identify the solution. The issue is in the DSL status window: see below the status of an working modem
Now, see below the DSL staus of this not working modem:
These are with same working BSNL telephone connection.
Also I have seen that for this non-working modem, the default gateway is "Blank". how could I set that too?
May you pl advise me how to fix these issue?
Type 192.168.1.1./main.html
admin admin
you should get a menu Advanced options
similar page:
http://i23.tinypic.com/nlpdhs.jpg
Select WAn .
Select PPP/PPPoE
vpi/vci 0 and 35
enter userId ( without @ bsnl.in ) and Pw
Save reboot at management. wait for two minutes.
Post Device info showing Fw software version etc.
similar page:
http://img133.imageshack.us/img133/6955/adslmn7.jpg
check in Diagnostics page failed components.
Feedback.
Do you need WIFI ?
abc_sk2002 said:
I am at jamshedpur and when I try to download, it is saying "Dear customer, we cannot extend this service to you as you are in different network ". Could you pls post the full link for downloading and procedure for updating the firmware?
Thanks.[/QUOTE
ISP's usually provide a link or ur browser will automatically go to the download page if and when there is a firmware update. It would also be wise to first contact ur ISP and confirm whether they have released any recent firmware update regarding ur modem. Firmware updates are usually released by ISP's when there is a major change in their networking protocol so I dn't think u should be too worried about this.I'm sure ur ISP will notify u if an update is neccessary.:thumbsup:
sorry, I was not able to reply earlier.
I need wifi. I did as per your advise for the wifi. Still the status is "down". I am uploading the required screen shots below. Pl suggest if there is any way to recetify the problem:
Software version:
Diagnostics :
If you are using "Dialer" mode go to wan page.
( IN Advanced Options )
Uncheck "bridged' select PPP/PPPoE
enter userId and Pw
etc. Save reboot wait for 2 minutes.
then try.
2. copy/paste this data
start run type cmd Ok
new window
type
ipconfig /all
feedback.
from the looks of ur modem's settings,lots of the settings seem to be wrong....ur LAN IP and the DNS server cannot have the same IP add. U need to correct the settings.Reset ur modem's settings to its default values n ask ur ISP technician to put in the correct values for the settings.
I did soft reset thru "restore factory settings" by logging in to the admin mode; nothing changed. Then tried thru hard reset (pressing the hard reset button by a pin head thru the hole at the bottom cover), but nothing changed. I have shown this to BSNL technician, he simply said tha the modem is gone and nothing can be done. Any help from anybody to reset these DNS and other settings will be of great help. Thanks.
get a new modem like the technician adviced you. If hardware reset has failed, its time 4 a new modem....simple as that.
if you can access the modem settings you can edit the entries and then save/reboot.
see wa3002-g4 sticky post in this forum for screen shots etc.
DNS also can be chnged , instead of automatically obtain dns.
Post your ipconfig /all data.
FW update NOT available for Type II siemens Nokia 1600 in Motive site. Self Care Software shall help you to:
http;//motive.bsnl.co.in
# Auto configure your Modem and Outlook Express
# Manage your Modem (CPE) seamlessly and keeps your connection Safe
# Remotely Troubleshoot your Modem by BSNL Customer Care
# Reconfigure your Modem and Outlook Express if the configuration is lost
Please Note : CPE Firmware Upgrade Application is ONLY applicable for UTStarcom (both Type 1 and Type 2), Nokia Siemens Networks(Type 1 ONLY) and ZTE Modems (both Type 1 and Type 2) supplied by BSNL. You wont be charged for downloading and using Self Care Software.....
