BSNL Broadband help regarding default modem wifi password
  • Thread starter Thread starter numera
  • Replies Replies 1
  • Views Views 14,712
numera
Bsnl
i am using modem beetel 450BX1
The problem is i cannot connect to wifi because it comes with default password
i didnt get any note of password with the modem
i tried resetting but again same issue
this is the screenshot of wireless security page
http://i44.tinypic.com/1razcj.jpg
As u can see network authentication is open .then also its asking for password
i doubt i have to enter 13 digit ASCII or 26 digit HEx code corresponding to'' current network key ie 1'' (as shown in fig)
so if u think i am right it will be helpful if u can tell me the asci or hex code
i know how to disable wifi password by entering lan settings but i have some problem with Lan port ,so only option is wifi
thanks
Disable WEP box. WIFI in unsecured mode.TRY. wifi mode. connect to Internet ?Mention OS being used .feedback.
