Hello brutalassasin, I'm also using the same modem as you.
Your modem might be configured in the bridge mode, just you need to change it to PPPOE mode.
yes if you are usign bridge mode these configuration will not be available, as i already mentioned my step 1
and if you are using bridge mode, no port forwarding require. Bridge mode (dialup like), is more easy to manage. connect/disconnect, scheduling of bridge mode is also easy. No need to reboot modem at 02:00am and 08:00am for night u/l.
so if you do not have some special purpose, using bridge mode is a good option.
