jackrabbit
Arrive.Raise Hell.Leave.
Hi,
I have a UT Starcom-300R2U and a Netgear WGR614 v6 wireless router. Earlier I had added my laptop in the DMZ(dematirialized zone) of the UT 300R2U, as I could not find any port forwarding options in it.
Now after setting up Wifi(I connect to internet via Netgear Router), I am unbale to do any port forwarding. I tried the portforwarding option, in the Netgear console but then internet completely stopped.
I use uTorrent to upload/download torrent, and hence I am in need of the correct way to configure both UT 300R2U and Netgear.
Here is what I did:
1. Gave a static Ip to my computer.
2. Added the same in port-forwarding part of Netgear as per instructions from www.portforwarding.com.
3. Netgear's Ip is 192.168.0.1.
4. UT 300R2U IP is 192.168.1.1.
5. Unable to access internet from laptop.
Kindly provide suggestions for my problem.
Thx,
Kirty![Unsure :unsure: :unsure:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f914.png)
Here is what I did:
Thx,
Kirty
