BSNL Broadband: need old firmware for siemens c2110
  • Thread starter Thread starter greatgk
  • Replies Replies 4
  • Views Views 3,620
greatgk
bsnl
need old firmware for siemens c2110..plzzzz new version is problem.i cant get login from pc.it is logged from modem after upgrade from motive.bsnl.co.in
If you can access modem settings pages mention the present version number.
Open modem / Edit WAN Uncheck
PPP/PPPoE and select "Bridged"
SAVE reboot wait for 2 minutes.
use Your Dialer to connect .
Select Calcutta telephones Link
( Last in the list ) from here
Sticky post of mine for Wa 3002-G4
Select C2110 menu pages.
If you can't over the web interface, then may be try telnet interface for the downgrade.
Hmm.. Got it. Your modem is working but setup to autologin PPoE. You can uninstall the motive software from your pc. Then go to the modem setup page (192.168.1.1 by default) and change the settings to manual (I assume the new firmware also has this option). Hope this helps.
