UTStarcom Support Portal Program https://login.utstar.com/Customer_Register.cfm
1. Try from the Horse's mouth ! You have to register there.
2. If you have not purchased the modem, exchange it to Smart Ax, explaining the problem to BSNL.
3 What are the firewall programs in Your computer ? Have you tried the Windows Firewall and entered exceptions there ?
4 Will try any specific ports if you mention it here I have both Airtel and
Dataone . bb connections.
5. Create a Netone connection and see whether the port is accessible. Rs6/Per hour plus TF charges. If you try between 2230 to 0630 four TF pulses only . Cost Rs 10/- plus taxes !/per hour. Maximum you can download will be 8 to 12 MB./per hour
Apoorva Khateja !
"Hey......no respect at all. I spent a lot of time writing this guide for IBF. This was meant for newbies."
Thank you ..I have saved the page ! It is a recurring topic here.
@essbebetried from the horse's mouth earlier itself.. they re sayin tht they won't support end user; asked me to contact my isp; bsnl ppl over here seems 2 hav no idea abt it.. i'm quittin tryin 4 the firmware update atleast 4 the time being;all u ppl.. thanks 4 ur support!!!
Hi .. I was also facing a similar problem .. I have the same modem with the same firmware .. Was getting some error in utorrent about port forwarding .. What I have done is entered my ip where it asks for DMZ server .. And I added an exception in the windows firewall with the port being used by utorrent .. that worked and I am able to download at a good speed now .. hope this helps .. I do have a question here .. if I open all ports and add an exception in the windows firewall then is my system vulnerable to virus / hackers? Thanks.Rahul
NAT problem - AzureusWiki
In tht "understanding wht NAT problem is" point no:9;
Even I've done tht.. seems no other way 4 Portforwarding in our router with this particular firmware.. try 2 get a firmware in which u'll have a virtual server setup 'n if u get tht plz do inform me..
Another option u can try is 2 switch over to bridge mode..
NAT is your internal IP, which is not globally routable. Thats why you need to setup port forwarding, since the router wouldn't know where to route the connection to. In UT300R2U, go to Advanced, Virtual Server, and that is where you setup port forwarding.
I am also having the same router.to do the port forwarding i went to router page and i did some thing i dont know what did.now the page i not getting loaded for me .It gives me the following page see the screen shot
members/anbutorrent/
You have posted the error message.
Confirm ,1. you cannot access Internet for surfing
2. or access the modem by using 192.168.1.1 admin admin.
3.If 2 above restart the browser and try.
4. In some model of UT300R2U there is no virtual server option. http://aycu14.webshots.com/image/28973/2005831266046767882_rs.jpg
http://img362.imageshack.us/my.php?image=utstar300r2ubd8.jpg
Which is your model ?
5.If you are confident of reprogramming the modem, with power on
use reset button or recess of the modem to restore factory defaults.
