my router automatically restated sometimes.when i turn off and turn on my router it takes so much to switch on.plz help me
s Check "Sticky" post wa 3002-g4 quick reference.
menu pages are same.
Go to Management and then SAVE REBOOT. wait for two minutes.
Change DNs to 8.8.8.8 and 208.67.220.220.
Also disable client_TR069.
Thanks for ur reply but still my router restart every 2-5 mins
try Dialer mode.
Check IDLE time is set to 0 in wan page
Uncheck box adsl2 +. in dsl menu.
Assumed your computer side all OK /perfect.
Anyway try to upgrade drivers for LAN ethernet card.
try Dialer mode.
thanks for ur reply.U r awesome.my router restarted 2-3 times when i switch it on.
And then all lights r stable.i can able surf a page without any problem.
