Thank you very much for your valuable reply, my bsnl dsl
router model no is DNA-A211-I. Moreover please provide my more detail information about the settings.
Thank you.
Please check my "Sticky" Post wa 3002_g4 quick reference guide.
Your wifi router is similar .
Ensure you select "Always On" PPPoE mode in the wan page.
( BSNL USERID/PW stored in the WAN page )
Enable DHCP in ( LAN page ), If you give a range of say 192.168.1.2 to 192.168.1.6
Only five systems will connect to Internet.( at a time )
Enter in TCP/IP properties page the address say 192.168.1.2. to 192.168.1.6 for 5 lapops.
About white list . confirm menu option available in DNA A 212 -1 ( i have not checked it up )
IN each computer
Start RUn Type cmd Ok
new window
type Ipconfig /all
You will get the
MAC ( Machine Access Code )address of the ethernet card or wierless lan card.
More on feedback.
