BSNL broadband wifi connection problems
  • Thread starter Thread starter 333rupesh
  • Replies Replies 1
  • Views Views 2,356
BSNL
Hello,
I have recently switched on to BSNL broadband and I have UTSTARCOM WA3002G4 ADSL modem + wifi router. I have done the usual procedure of setting up broadband and wifi by logging in to 192.168.1.1 by connecting ethernet cable to my laptop. The wired internet and wifi were working fine after i set up for the first time, but when I unplug the LAN cable from my laptop and restart my modem by pressing the power button (with LAN cable still unplugged), all my devices are not detecting the modem. In this case each time when there is a power outage/ maual restart of the modem, I manually login to 192.168.1.1 by reconnecting the lan cable to my laptop and click Save/Apply in Wireless - Basic settings and then my wifi connection shows up.
I need some help to skip this manual Save/Apply each time.
Please help me on this.
Thanks in advance
Hi ,
Can you post the internals of the modem ? or if you are in chennai , I can give you a firmware to try on .
