BSNL DataOne: I am here to help
  • Thread starter Thread starter kambui
  • Replies Replies 523
  • Views Views 133,637
Status
Not open for further replies.
@ Raja , :) I assumed that you knew it before .
I've given the Link just because of its simplicity !
I donot have experience with this problem . however ,
again ignore this if you already knew it : Link
____________________________________________
@ Ravinder , we need to know whether it is DSL
502T or GLB 502T to respond to your query .
however you may see this : Link
_____________________________________________
@ Mohammed , we donot suggest to keep modem
always on . It generates more heat in idle codition . And
heat affects the functioning of the modem . I use a power
switch for modem's adapter & switch off it when not in use .
Dear Seshu,
Oooops....! Please I meant no offense when I said I knew about the No-Ip thing. Damn sorry if it offended your noble sentiments of offering help to BSNL BroadBand users.
In fact I am a novice at such things and depend heavily on guidance from folks like you. I still feel I am in square one as far as my prblem is concerned. First of all please tell if it is possible to set up the Smart AX MT882 to allow others to access my PC using the Currently asigned Dynamic Ip Address. If so, please guide me about the changes that need to be made on the modem settings.
Thanks,
Raja.
@ Raja , I didnt mean to hurt you .
Let me remind a couple of basics :
1) the server needs to have a static internal
(LAN) IP address : Link
2) we have to use port forwarding (port 80) : Link
And this previous Link has the complete details .
MT 882 has virtual server setting (in advanced settings) .
you should be having its manual (in pdf format) . just see
it once again .
see also this
And you may see the following for further guidance if required :
Link1 Link2 Link3
WE HAVE
One ERP IBM server installed and connected with d local computer in network thro' switch.(ip:192.168.0.100)
OS:SBS 2003 SERVER,DOMAIN BASED
There erp software also working by just type the url htp://192...100//xxx/login.xxx
They took a public ip with 59.xx.yy.zz with subnet mask 255.0.0.0
now this is bsnl broadband and connected to d server with another lan card.
router ip 192.168.1.1
From any local network pc we can login to router thro' server,using d erp software,using internet thro' proxy.
our main aim s to connect this server from outside thro' internet and use d erp software by typing http://59.xx.yy.zz/xxx/login.xx
but it s not happening.
we chkd ...no firewall..NAT SETTING ON but all entry disable.we just add in http: nat entry with 59.xx.yy.zz.so fm outside(thro' internet) when i type 59.xx.yy.zz i m able to access the router.but not d software.how to enter d NAT setting.
ALSO we tried with vnc loaded n the server and thro' vnc viewer it connects sometime and not always.
hope u understand my pb.
technical details:
it s Sterlite Huawei SMARTAX MT841 DATAONE BRANDBAND BSNL ADSL MODEM CUM ROUTER.
I WAS NOT ABLE TO FIND ANY PORT REDIRECTION IN THIS.
^ ignore this if you knew it before
as I understand it , port forwarding is done thru NAT entries
Go to Advanced ->NAT -> NAT Entries.
The popular applications might be already listed.
Click on Note icon and edit the status ( scroll down
the page to edit). You can create your own entries
by clicking on New icon.
see : dataone help document
MT-841 port forwarding
Greetings people.. I plan to make an upgrade from Home 500 to either Home UL 900 or Home UL 900 Plus. Can anyone tell me which one is better?Also BSNL tariff for Home UL 900 says: "MCU charges per Pulse @ Rs. 1/- shall be applicable" .. Does that mean i have to pay extra, apart from the mandatory Rs. 900/month? Any clarification in this regard would be greatly appreciated.
^ it is difficult to decide which plan is better .in UL 900+ plan , no free phone calls are available ;monthly phone rental is zero and each phone call unit is charged at Rs 1/- in UL 900 plan , monthly phone rental & free calls are as per the taken phone plan . extra phone callsare charged according to the phone plan .in general , if you regularly make more STD calls then UL900+ will be better .
Thanks for the info Seshu! I usually download/upload around 9GB/month with the help of night unlimited, and i'm finding it increasingly difficult to stay within the 1GB limit. Would u recommend the upgrade from Home 500 to UL 900+ or should i continue with the existing plan? Also are there any known problems with the UL 900+ plan?
^ I do recommend to take UL900+ plan . withunlimited plan one need not worry about thedata limits , scheduling downloads & health :) in metro cities , some users have been facing problems with speeds . I'd suggest to enquire in your neighborhood whether any one with unlimited plans facing the speed problems ...
@SeshuYou bet i haven't got a decent night's sleep in months cos of Night Unlimited :wacko: , and even schedulers are of no use if the connection gets broken. Btw, is there a scheduler to start the dataone connection at a specified time? Of course, there's windows task scheduler, but i can't figure out how to do it. Perhaps u could try it out and hopefully come up with something?
Status
