Just got bsnl 256k broadband connection. Most of the time I am unable to log on to the internet.When i try to connect i get the "error 815" message. I get the foll. message:-
windows confirmed that "Primary
DNS Server" is currently online but is not responding to connection attempts at this time.
This usually means that a firewall is running somewhere between the two computers and is blocking "domain". Windows has confirmed that Windows firewall on this computer is correctly configured to allow this connection.However a remote firewall might be blocking your connection. "
I am using windows vista and the firewall on my computer is configured correctly.
Anyone got any idea what this means and whether it's because of bsnl or because my network connection isn't configured correctly?? has anyone faced similar problems before??
Even when it gets connected it doesn't last for more that 12 hrs. After that it gets disconnected and doesn't connect back for a while. It is not a network problem since i am able to ping and the inter
I also notice one more thing---- when i connect to the internet , my network and sharing center shows two things---
Broadband and network. Sometimes my network access is local and internet whereas during other times network access is local only. It is during those times(when network access is local only) that i start to face a whole lotta problems ------ erractic torrent speeds frequent disconnections,etc,etc.
Anyone got any idea what to do----BTW, i am using windows vista and windows firewall.
Also FYI,
the modem is set to PPPoE dailing. VPI:0, VCI: 35
Also In WINS configuration , my netbios settings is set to default(.i.e use netbios settings from the DHCP server and i have checked the 'enable LMHOSTS lookup.
Under the Ip settings tab, my interface metric is 4248 and have deselected the automatic metric.
And under the DNS tab(Vista's Network and sharing center---------->Network view status--->Properties---->TCP/IPv4 properties---->advanced tab),i have selected the "append primary and connection specific DNS suffixes". i Have ticked the "append parent suffixes of the primary DNS suffix."
Also ticked, "register this connection's addresses in DNS".
Soomeone tell me have i set the connections wrong ??
And both the broadband connection and network are set to private network(with Network discovery, File sharing and Password protected sharing set to on).
I havn't done any port forwarding nor did i set my modem as a
router.Also my modem does come with a built in firewall. Any help or suggestions will be helpful!! Thx in advance.
