I am also really tilted due to this I don't care about ping bro but packet loss is way too much I get around 50-70 ping in valorant and thats okay without packet loss. Any way to fix this. I tried fixing it by hosting my own VPN services on cloud but that didnt help because I dont know how to do the routing and stuff. Also, exit lag works pretty well but expensive it gives me around 50 ping without any packet loss.
Totally agree that BSNL Fiber is a crap. I live in Pondicherry round the city corner here except BSNL I dont have any other option. It is a sin for FPS gamers like me to live in this area as you will be left only with BSNL as a option. But you cant play online multiplayer games where it require a good internet. Recently have started facing one more issue where the game itself will not run due to anti cheat or failed anti cheat authentication error. I tried various method before knowing it was due to that stupid so called BSNL issue. Then finally figured it out that it is due to this crappy BSNL network settings that they have made in recent updates. Now i ended up using mobile data but u all know what will happen on mobile data, just to give an example from 3 KD pre match I successfully dropped to 0.4
@GeminiYT Cloud flare Warp can eliminate this error , if you are extremely lucky you might get better routing (via -WARP Singapore colocation center ). In my case my warp connections are unstable and routed via Bombay sometimes Frankfurt or Los Angels.
