Bsnl never does anything Right
  • Thread starter Thread starter dhanvanth
  • Replies Replies 26
  • Views Views 3,596
i have applied for plan change ul750 plus to home500 on 24 april. they changed my plan according to my request on 1st may. but they left the status as "open". i am getting only 256kbps speed. i never downloaded less than 25gb every month. may is worst to me. just used up 2238mb and 1654mb unbilled usage :ashamed: what should i do? shall i go to exchange and ask them for discount in the bill?
you should have complained earlier at the bsnl exchange to reset your speed to 2mbps. mostly the bsnl officials wont consider changing the bill or giving discount on it. did u atleast complained now?
i am doing circles(pradakshina) around bsnl office every day. it is not as far as 1 km. they say plan conversion is completed:cry:
well..contact higher official nd say that u had enough and mention all your problems to him..he might get the work done from you..nd yes!! i dont think they r gonna give u any discount for this...
Friends i am new to dataone and this forum... i need ur help....
1. i got bb on mid of april and the billing cycle of that month ends and i paid the rent for apr
so the next billing cycle consist the months may and june....
i applied the plan change from home 500cplus to home ul750cplus
till may 28, on the usage portal, the two differnt heading showed the daytime usage details and night unlimted usage details....
but today june 3 when i check the may month usage it shows total usage that includes night unlimted usage too and shows 30gb but actually i used 27.5 gb on night unlimted time and the time shows correctly too
i am scared that am i charged for toal 30gb?????
and the next one is 2 nd june evening only my plan is changed to unlimted.... the potal shows this unlimted plan and also status is open...
but usage chart lists the 1st and 2nd of june usage details...
now can i use my broadband unlimeted... because the order details shows
Order Type Plan Change Plan Name Home UL 750 Plus Order Status Open
now can i use unlimted download.....???? and my download speed is also not changed and bandwidth meter shows till my speed is 1.64Mbps
@mohanBBno problem with speed or plan change. you can use net happily. don't worry about speeds. once it gets provisioned, you will get 256 kbps speed. same thing happened for me in april. i downloaded more than 5gb in one day. status was open on that day. but i got bill of 870 only.Note: if you have any more doubts, please visit your customer service centre tomorrow immediately. this will do good for you:thumb:
/members/mohanbb/
Welcome to Broadbandforum.in
See the summary at the top of your usage page for MAY.
Billing cycle in Chennai is monthly.
All tariff plan changes normally effective from 1st of the month.
Post screen shot of your June usage. ( with Summary on the page top )
Call customer care 1500 and confirm Plan change to 750 U/L . If you get fast speed
means the change is not effected.
send email to denibchn@dataone.in quoting ref numbers. ( ack for plan change etc )
my usage in june is
Broadband Usage Details for the Month of JUN-2008-UnBilled Total Data Transfer(In MB) : 23 Sl No
Start Time
Stop Time
Download (KB)
Upload(KB)
Total(KB) 1
2008-06-01 10:31:51
2008-06-01 12:16:12
2862
598
3460 2
2008-06-01 13:06:37
2008-06-01 13:10:00
3441
120
3561 3
2008-06-01 22:20:24
2008-06-01 22:26:45
3127
126
3253 4
2008-06-02 09:37:00
2008-06-02 10:06:27
12612
1189
13801but after that tooo i used bb... but the plan change occures only on 2nd june afternoon....
after plan change there is no usage records eventhough i used many times afterthat
friends pls tell shell i use unlimeted or not
only use unlimited if you are getting less speed(256kbps for home750 & 512kbps for home1350).if you are still getting 2mbps speeds then your plan is not changed.
