Bsnl ul 750 plan!pls help!
  • Thread starter Thread starter rohanchauhan
  • Replies Replies 30
  • Views Views 4,998
2. Download speed is 1 mbps throughout and upload speed is 9 - 12 mbps. I had a 512k connection but since I'd taken part in the beta test, my speed was upgraded to 1 mbps. No fup.
In a nutshell, I'm hanging on to the connection only because of the upload speed.
upload @12mbps! thats crazy! all reverse ratios here.. why do u need that upload speeds?
i have a cctv surveillance system at business and need a high upload speed plan for constant streaming.. all i get with uld1350 is 1mbps!
and nope, i checked.. ftth is far far away from coming to aurangabad! :(
How come you're getting 1 Mbps upload speed? as the max. speed you can get is 768 Kbps.
i shouldn't get download more than 4mbps either.. check the speed below! reason: raised speedcap, pretty good SNR (ranges between 42-38)
High upload is very useful for seeding torrents :D
@pkmishra
900 kbps upload on 2 mbps download here on copper/dsl. They seem to have increased it, used to 700kbps earlier.
Oh, nice...lucky you!
Well, i'm using a seedbox as i can only get a max. upload speed of 500 Kbps.
Hope it's declared officially soon enough.
Can you temme what's the max. upload speed they're providing in the ULD plans?
My plan is ULD 750 combo and i'm getting a max. of 500 Kbps upload speed.
I think apart from mtnl (and maybe beam), no other large isp categorically mentions a specific upload speed. That said , our lines can handle max of 1mbps. I used to get 600kbps earlier, then 700 and now 900 kbps. I'd requested them to reset my speed profile.If your line quality is good except upload to be in the region of 700 - 970 kbps, else 500-650 kbps is what most people get.My plan is 1000uld combo.
download : upload in ADSL connections are configured either in the ratio of 1:4 or 1:8, it should be which ever your closest to! in your case.. 1:4 i. e. 512kbps
^^Even I was under the same assumption, turns out its not like that. Else, he'd be getting 256k upload, and me 512k upload.
Yes, you're right otherwise why would they provide a max. of 768 Kbps upload speed for the plans involving 1 Mbps and above download speed.It's not configured based upon the ratio forsure.
