My upload usage is very hight as compared to download usage and also data transfer rate is very high when no programme is running hust connected. pLease help
@kapirakhani
Welcome to broadbnadforum.in
Kindly give the following details in any post.
Modem model/make /number.
Whether problem , started recently.
2. Download Anvir Task manager from Windows task manager processes, Windows startup, Startup programs, Vista tweaks
and check your start up programs. You can
disable most of them, which you don't often use.
thanks for help. I dowmloaded anvir task manager and noted many strat up files. I removed some of them which were not in use as per my knowledge. now data transfer speed is reduced but still my upload is showing more than download. This problem has been started recently.
Perform a full system scan using CA Yahoo antispy. It could be a virus.
Type each member's post/suggestion, as given above above and
give result feedback. tried /Not tried. No improvement.
