Cable Quality on LCD TV
  • Thread starter Thread starter Lokesh
  • Replies Replies 4
  • Views Views 2,682
Lokesh
Regulars
Trib 649_Combo
Which provider provides with the best signal and quality cable feed?I have Bravia 26" (KLV-26S400A) which support 1368*768 pxls and the current local cable connection is often pixelerated (if that's the correct term) and in all the quality is so-so. Which provider should I go for?Anyone offering hdtv or atleast co-axial output from their set-top boxes? (In South Delhi)
I am using digital cable right now (1 Video and 2 audio (white and red))Can we use the (i think, component video cables) the ones with in total 5 plugs ???does any set-top box provide such feature?Also, what about MTNL IPTV???
hi,
Buy reliance Bigtv, use s viedo out in set top box and in ur tv s video in,,reg audio use av out in set top box and av in in ur tv,, then see ur quality in tv,,,:thumbsup:(if sun dth is ok) or check with mtnl ip tv,,becuse i dont know i am in chennai.( s video cable available in market ,,but cost 900 rs ,,optical s video good quality)don't buy local quality,,,
