can I use ethernet cable given by bsnl
colour screen
bsnl unli
I was said that the ethernet cable given by bsnl is not of high quality because modem costs Rs.1200 while good cables cost Rs.250. I was said that the cable given with ut starcom bsnl modem is worth Rs.50.i am having frequent disconnections and re-establishment of connections and sometimes have to restart computer if ethernet disconnects. ADSL signal is there. Windows taskbar shows 'ethernet disconnected' or something like that. so no adsl problem, only ethernet problem.what do you think is the problem? is there problem in ethernet card/port or is problem there in cable?
it is unlikely that the cable would be fautly. make sure your connections are proper. try using another cable.
250 rs for cable?!! its just 1 mtr cable. if u crimp urself it wont cost even 20Rs.
