chronic disconnection problem on bsnl broadband
  • Thread starter Thread starter bharatk8
  • Replies Replies 1
  • Views Views 1,330
bharatk8
BSNL
frequent dis-connection of dataone « on: Today at 05:36:13 AM » --------------------------------------------------------------------------------My broadband connection gets dis-connected frequently,when I try to open any site it times out,many times ping shows ms value of 100,200,300,400,500+,many times i am not able to open 192.168.1.1 site.Eventhough I have changed motherboard and ram problem continues.I was told to check status of broadband line on 192.168.1.1 Broadband Line Status Refresh Line Rate 54124 Tx Cell Transmitted 0 Rx Cell Received 0 Cbr_CPS 0 Rvbr SCR_CPS 0 Vbr SCR_CPS 0 Rvbr PCR_CPS 0 Vbr PCR_CPS 0 Ubr_CPS 12075 Ubr MCR_CPS 0 CACMode Simple CACFunction 0x2002a4cc Port Speed Hook 0x00000000 Vpi Range 8 Vci Range 16 Default Pcr 0 Traffic Shaping false Ni Type uni Is Dsl Dma Up 1 Enabled Channels 3 Driver Version 1.75 APIVersion GS_API_626 Firmware Version E.37.7.37 Dsp Version 0x00000090 Common Handshake Disable Connected true Operational Mode G.Dmt.Bis State Showtime Watchdog 0x00000053 Operation Progress 0x00000000 Last Failed 0x00000000 Tx Bit Rate 1024000 Rx Bit Rate 2868597 Rx ATTNDR 2864474 Code Type Status AnnexA Tx Cell Rate 2415 Rx Cell Rate 6765 Phy TXCell Count 269110 Phy RXCell Count 446594 Phy Cell Drop Count 1 Overall Failure 0 Data Boost Enable Local ITUCountry Code 0x0000b5ff Local SEF 0 Local End LOS 0 Local SNRMargin 6.5 dB Local Line Attn 50.0 dB INPup 1.97 INPdown 5.76 PMstatus L0 Raw Attn 0.0 dB Local Tx Power 12.3 dB Local Fast Channel Rx Rate 0 Local Fast Channel Tx Rate 0 Local Fast Channel FEC 0 Local Fast Channel CRC 0 Local Fast Channel HEC 0 Local Fast Channel NCD 0 Local Fast Channel OCD 0 Local Interleaved Channel Rx Rate 2868597 Local Interleaved Channel Tx Rate 1024000 Local Interleaved Channel FEC 0 Local Interleaved Channel CRC 0 Local Interleaved Channel HEC 0 Local Interleaved Channel NCD 0 Local Interleaved Channel OCD 0 Remote Tx Power 20.5 dB Remote SEF 0 Remote LOS 0 Remote Line Attn 36.0 dB Remote SNRMargin 6.0 dB Remote Fast Channel FEC 0 Remote Fast Channel CRC 0 Remote Fast Channel HEC 0 Remote Fast Channel NCD 0 Remote Interleaved Channel FEC 0 Remote Interleaved Channel CRC 0 Remote Interleaved Channel HEC 0 Remote Interleaved Channel NCD 0 Local Mgmt FEC0 85462 Local Mgmt CRC0 203 Local Mgmt FECErrored Sec 1362 Local Mgmt Errored Sec 93 Local Mgmt Severely Errored Sec 0 Local Mgmt LOSErrored Sec 0 Local Mgmt Unavail Errored Sec 0 Local Mgmt HEC0 130 Remote Mgmt FEC0 0 Remote Mgmt CRC0 0 Remote Mgmt FECErrored Sec 0 Remote Mgmt Errored Sec 0 Remote Mgmt Severely Errored Sec 0 Remote Mgmt LOSErrored Sec 0 Remote Mgmt Unavail Errored Sec 0 Remote Mgmt HEC0 0 Local TPSTCCell0 10713610 Local TPSTCCell0Upper Layer 446592 Local TPSTCBit Error 0 Remote TPSTCCell0 0 Remote TPSTCCell0Upper Layer 0 Remote TPSTCBit Error 0 PSDMask Status Standard Status Fail Count 0 Profile Status MAIN Action Startup Activate Line None Line Status false Host Control Enable Auto Start true Failsafe false Showtime Led 2 Retrain EnableOverallOnly Defaults None Line Mode None Whip Disable Whip Active Inactive Happy Mode Enable PMmode L2L3Allowed Dying Gasp Enable Utopia Interface Level1 Physical Port 0 Clock Type Oscillator Profile MAIN Detect Noise Disable Max Interleave D 64 SHalf Disable Cabinet Mode Disable PSDMask AnnexM-EU60 Standard Unknown (542) Ec Fdm Mode EC Max Bits Per Bin 15 Tx Start Bin 6 Tx End Bin 63 Rx Start Bin 6 Rx End Bin 511 Rx Auto Bin Adjust Disable Tx Attenuation Bis_0DB Bit Swap Enable Bit Swap Up Enable NTRMode Disable Code Type ADSL2A Max Down Rate 511 Capability BIS+/BIS/GDMT/T1413 Coding Gain auto Framer Type Type3ET Fast Retrain Enable Reset Defaults false Port Snmp If Index 0 Port Snmp If Type 0 Person who does maintenance on behalf of BSNL has informed that his workload has increased in summer.This sounds very odd.Pl. suggest remedy.
You SNR is too low around 5 db and Attenuation is very high 50 db call the Customer Care of BSNL and tell them that SNR is very low and they will do something to help you but it will take more than 2 weeks Have you connected the wires in Splitter correctly disconnect the phone and then try if still not stable linkconnect the main phone line directly into modem after disconnecting phone line and then check
