How to resolve frequent disconnection problem on BSNL Broadband?
  • Thread starter Thread starter MEGAN
  • Replies Replies 32
  • Views Views 3,253
hmm i searched .. i dont have that option in my modem.. ut300r2u ,also when i searched ,may saying its unsafe.. ,whats it about anyway.. and torrent yes..upnp is on already..
yes, upnp is less secure but more convenient if available. your router also needs it so client can request to open port.
another way is to manually port forward. it should be under something like "Virtual Server"
i see some nat-dmz option and some tweaks in it..
NAT -- DMZ Host
The DSL router will forward IP packets from the WAN that do not belong to any of the applications configured in the Virtual Servers table to the DMZ host computer.
Enter the computer's IP address and click "Apply" to activate the DMZ host.
Clear the IP address field and click "Apply" to deactivate the DMZ host.
so it will fasten my torrent download speed? if i do this..
yes, this is not the safest method because itll basically open all the ports to your pc. but ya itll speed up your download as you are able to connect with more peers.
ohh damm ... i dont think this a good idea lol.. by the way how to do a safe port forward then.. .. also i kinda understand i guess ..that even if i had more peers in torrent still not dowloading..fast so this port forwarding thing will allow those peers to open up and i can download faster.. so this is how it works ?
Your router doesn't seem to have the option but usually it's under "Virtual Server" or "Port Triggering"
You specify from port and to port and the in some cases the ip address.So only one port is forwarded instead of all.
you can forward any random port (ideally above 10000 for security). having forwarded port will result in more connections with peers.
Try 192.168.1.1/scvrtsrv.cmd?action=view
what do you see on this page?
by the way i have nat pmp upnp port mapping enabled in torrent already.. its also showing a port number -random port used for incoming connections.. ,only some torrents with no dht seeds wont download a thing.. so want to work around how to get downloaded from those kinda torrents
