find Network tools and Network in Sysem setting menu. There you have to check the LAN Ethernet card. Right click on the same open options and put your ip address and dns entries over there. If you are going to DHCP select DHCP. Click okay. Thats it you are all set to go. Open firefox there you go !!!
